Knots 101
Catch-all for all other types of fishing...
BornBad
Knots 101
Post by BornBad » March 30th, 2005, 5:22 pm
Palomar Knot - An all purpose hook to line knot. Very quick to tie and reasonably strong.
I take that life if I can, with regret as well as joy, and with the sure knowledge that nature’s ways of fang and claw or exposure and starvation are a far crueler fate than I bestow. – Fred Bear
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:23 pm
Hook Snell - Quick and simple method of attaching line to a hook with an up or down turned eye. Can only be used with a free length of line as both ends must pass through the eye.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:26 pm
Uni Knot - This versatile knot can be used can be used for connecting hooks, swivels, rings and lures. Its main advantage is that it retains virtually 90% breaking strain. Easy to tie even in the dark after practice.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:28 pm
Perfect loop - One of the better loop knots and can be used on lighter lines although best suited to the heavier. It will not kill the action of the lure or fly.
Function: Connecting lures or fly to heavy leader, trace or shock tippet.
Strength: Retains 70+ strength
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:29 pm
Longliners Knot - For attaching a hook line to a continuous heavy main line. Will not slip up or down the line
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:30 pm
Hook Snood - This is a high strength knot to attach trace line to a hook. It's main advantage is the hook will lay along the direction of the line.
Note that the length of the trace will be the length of the loop.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:32 pm
Half Blood Knot - This is a high strength multi purpose knot. It's main use is to attach swivels, hooks and lures to the main line.
Assist the formation by pulling down on the roll towards the base.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:33 pm
Grinner Knot - This is a multi purpose knot that is more securely clinched than it's relative blood knot. It's use is attaching swivels, lures, and hooks to the main line.
Assist its formation by pulling down to the base.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:35 pm
Dropper Loop - Creates a stand out loop for attaching a hook to a trace. Handy in that it can be tied anywhere along the line.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:36 pm
Clinched Half Blood - This is a high strength multi purpose knot. It's main use is attaching swivels,lures or hooks to the main line. Formation should be assisted by pulling down to the base.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:38 pm
Centauri Knot - This knot is principally used to attach hooks through the eye to the line. Works well on a wide range of line strengths and claims to retain 96% of breaking strain.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:39 pm
Butterfly Dropper - Quick and easy to tie. Creates a loop that will stand away from main line. Is most suitable for lines over 15 kilo. Can slip if not tightened properly.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:40 pm
Albright Knot - This knot is used to join two lines of different thicknesses. It is used to attach a heavier 'leader' (rather than a double) to a lighter main line. It requires careful forming of the loops.
BornBad
Re: Knots
Post by BornBad » March 30th, 2005, 5:41 pm
Blood Bight Knot - This knot is used to create drop loops in light line traces. Its advantages are that the dropper tends to stand out from the main line and it's reputed 95% retained breaking strain.
Rafe Hollister
Former MOTY
Re: Knots
Post by Rafe Hollister » March 30th, 2005, 5:42 pm
Don Knotts- Internationally-known comedic actor, most often recognized for his portrayal of lovable, bumbling, sincere Deputy Barney Fife on The Andy Griffith Show.
"I'll tell you one thing about women, they don't give a damn about things on the side of the road."
- Tim Wilson
