Hooks 101
Catch-all for all other types of fishing...
BornBad
Hooks 101
Post by BornBad » April 6th, 2005, 1:44 pm
O?SHAUGHNESSY: This hook is named for the specific design of the hook. It?s a standard hook, forged with a very strong bend. This hook is relatively thick, very strong, and not likely to bend out of shape. It is good for general bottom fishing use.
I take that life if I can, with regret as well as joy, and with the sure knowledge that nature’s ways of fang and claw or exposure and starvation are a far crueler fate than I bestow. – Fred Bear
BornBad
Re: Hooks
Post by BornBad » April 6th, 2005, 1:45 pm
ABERDEEN Are generally made from shaped wire. Unlike the O?Shaughnessy, it can and does bend. It can be bent back into shape several times before it becomes too weak. However, once a fish is hook and the barb has completely penetrated, this hook holds quite well. These hooks are modified with bends in their shanks for use in jig molds.
BornBad
Re: Hooks
Post by BornBad » April 6th, 2005, 1:47 pm
CIRCLE Perhaps the best innovation in hooks to come along, circle hooks promote healthy catch and release. The design of the hook itself, when used properly, prevents fish from being hooked in the gut. Many anglers have a problem using these hooks because they require no hook set. If you do try to set the hook, it will generally come out of the mouth of the fish. These hooks are designed to move to the corner of the fish?s mouth and set themselves as the fish swims away from you. Anglers feel a bite and simply begin reeling, slowly at first, then faster as the hook gets set.
BornBad
Re: Hooks
Post by BornBad » April 6th, 2005, 1:48 pm
LIVE BAIT These hooks generally have a shorter shank than other hooks. Whether that is to allow the live bait to swim more freely or to be less apparent to the fish is debatable. These hooks come in regular and circle designs. Regular live bait hooks will be swallowed and result in gut hooks most of the time. Circle live bait hooks provide a greater chance for a good release.
BornBad
Re: Hooks
Post by BornBad » April 6th, 2005, 1:50 pm
KAHLE The curve on these hooks makes them ideal for live bait. Made from the same wire as the Aberdeen hooks, they will bend if hung on the bottom of some structure. However, once a fish is hooked, the design of the hook prevents it from being straightened.
BornBad
Re: Hooks
Post by BornBad » April 6th, 2005, 2:00 pm
BornBad
Re: Hooks
Post by BornBad » April 6th, 2005, 2:01 pm
