New Boat question??
Posted: April 6th, 2004, 1:26 am
by Hunter91
Not sure if this is the right subject to put this under. I got a new to me boat today. A 17ft 96 generation 3 boat with a 1998 90 hp Yamaha on it!!Big boat for someone used to a 14 ft jon boat. The engine fuel is to be premixed. It is not oil injected. Does anyone know offhand or have any suggestions on the mixture ratio? I will be looking for a yamaha dealer sometime tomorrow to tell me if someone here doesn't have any suggestions. Thanks
Re: New Boat question??
Posted: April 6th, 2004, 8:11 am
by fishnxs
Be safe and check with your dealer. I mix at 1 pint of oil to 6 gal super premium gas.
Posted: April 6th, 2004, 5:40 pm
by RB
50 to 1 is the mix for an outboard. Only buy tcwIII rated oil. The formula is on the bottle. I use quicksilver and have never had an outboard problem. I usually put a little extra oil in. smoke is better than burnt pistons.
Posted: April 7th, 2004, 12:08 am
by Hunter91
Thanks fellers. I did check with a dealer and he agreed the 50 to 1 ratio. Tried it out this evening at the rock. Ran like a top.
Posted: April 7th, 2004, 4:58 pm
by coyotewhacker
Sounds like you got this thing whupped pretty good. Rainbow is right on when he says a little smoke is better than burned pistons. If you do a lot of low speed idling, you might want to check for carbon on your plugs from time to time, also. Normal use with mostly high speed running should keep the carbon from building up.
Posted: April 11th, 2004, 10:03 pm
by bullitt
CW,it's funny you should mention plugs. Or not funny.
My Yammie wouldn't come out of the hole sat am. Acted like it was full of water or something. I kept it hammered, and when it did come out, it would only turn 4200 rpm. Turned out to be plugs, thank goodness. Still cost me 2hrs fishing in the rain and a trip to Cassville.
Hunter91, Congrats on the new rig. Your Yammie is made to run on reg unleaded. I think you'll like it. Have fun!
Posted: April 12th, 2004, 10:37 pm
by falcon
Posted: April 13th, 2004, 8:38 am
by Triton X2
Falcon, didnt you just get your boat back? Was it the motor you were having trouble with in the first place....Isnt it new enough to have extended warrenty on it? congrats on your placing in the tourney....
Posted: April 13th, 2004, 9:30 am
by falcon
Triton, no I've had the boat back for a while now, I just had the prop re-done and the lower unit grease changed and a new water pump put in, pretty much just regular maintenance, I had some other stuff done but it was to the boat itself. the motor's a 96 so it's out of warranty.
Posted: April 13th, 2004, 3:44 pm
by buckeye
I can relate to the motor blues, took mine out saturday, it ran fine til I went to put it on the trailer, it died and has'nt ran a lick since. Hoping my plugs are fouled but ya never know.
Posted: April 15th, 2004, 11:45 pm
by bullitt
Dayum Falcon, that's some serious bad news. I mean that really sucks! I'm at LOZ this weekend, but if you need a fix just shoot me a pm. You know where I'm going to be. Just get in the Skeeter and hang on, I'll drive, but we gotta fish your spots!!!!!!!!!!!
Seriously, that does suck. Good luck with the insurance reptiles.
