Page 1 of 2
Knots 101
Posted: March 30th, 2005, 5:22 pm
by BornBad
Palomar Knot - An all purpose hook to line knot. Very quick to tie and reasonably strong.
Re: Knots
Posted: March 30th, 2005, 5:23 pm
by BornBad
Hook Snell - Quick and simple method of attaching line to a hook with an up or down turned eye. Can only be used with a free length of line as both ends must pass through the eye.
Re: Knots
Posted: March 30th, 2005, 5:26 pm
by BornBad
Uni Knot - This versatile knot can be used can be used for connecting hooks, swivels, rings and lures. Its main advantage is that it retains virtually 90% breaking strain. Easy to tie even in the dark after practice.
Re: Knots
Posted: March 30th, 2005, 5:28 pm
by BornBad
Perfect loop - One of the better loop knots and can be used on lighter lines although best suited to the heavier. It will not kill the action of the lure or fly.
Function: Connecting lures or fly to heavy leader, trace or shock tippet.
Strength: Retains 70+ strength
Re: Knots
Posted: March 30th, 2005, 5:29 pm
by BornBad
Longliners Knot - For attaching a hook line to a continuous heavy main line. Will not slip up or down the line
Re: Knots
Posted: March 30th, 2005, 5:30 pm
by BornBad
Hook Snood - This is a high strength knot to attach trace line to a hook. It's main advantage is the hook will lay along the direction of the line.
Note that the length of the trace will be the length of the loop.
Re: Knots
Posted: March 30th, 2005, 5:32 pm
by BornBad
Half Blood Knot - This is a high strength multi purpose knot. It's main use is to attach swivels, hooks and lures to the main line.
Assist the formation by pulling down on the roll towards the base.
Re: Knots
Posted: March 30th, 2005, 5:33 pm
by BornBad
Grinner Knot - This is a multi purpose knot that is more securely clinched than it's relative blood knot. It's use is attaching swivels, lures, and hooks to the main line.
Assist its formation by pulling down to the base.
Re: Knots
Posted: March 30th, 2005, 5:35 pm
by BornBad
Dropper Loop - Creates a stand out loop for attaching a hook to a trace. Handy in that it can be tied anywhere along the line.
Re: Knots
Posted: March 30th, 2005, 5:36 pm
by BornBad
Clinched Half Blood - This is a high strength multi purpose knot. It's main use is attaching swivels,lures or hooks to the main line. Formation should be assisted by pulling down to the base.
Re: Knots
Posted: March 30th, 2005, 5:38 pm
by BornBad
Centauri Knot - This knot is principally used to attach hooks through the eye to the line. Works well on a wide range of line strengths and claims to retain 96% of breaking strain.
Re: Knots
Posted: March 30th, 2005, 5:39 pm
by BornBad
Butterfly Dropper - Quick and easy to tie. Creates a loop that will stand away from main line. Is most suitable for lines over 15 kilo. Can slip if not tightened properly.
Re: Knots
Posted: March 30th, 2005, 5:40 pm
by BornBad
Albright Knot - This knot is used to join two lines of different thicknesses. It is used to attach a heavier 'leader' (rather than a double) to a lighter main line. It requires careful forming of the loops.
Re: Knots
Posted: March 30th, 2005, 5:41 pm
by BornBad
Blood Bight Knot - This knot is used to create drop loops in light line traces. Its advantages are that the dropper tends to stand out from the main line and it's reputed 95% retained breaking strain.
Re: Knots
Posted: March 30th, 2005, 5:42 pm
by Rafe Hollister
Don Knotts- Internationally-known comedic actor, most often recognized for his portrayal of lovable, bumbling, sincere Deputy Barney Fife on The Andy Griffith Show.
