Whitetail deer are great escape artists, and that is another key to their successful strategy for survival. Their style of escape is a high speed sprint which puts obstacles between themselves and their pursuer. They can also play cagey tricks: they might hide and remain hidden until the predator is very near, and then make an explosive escape...they're gone down a well known escape route before the confused predator knows it. They will cross their own path, sometimes circling and crossing many times, to make their trail confusing. They will slink away on their bellies. They will walk in water to delete their trail, and will even hide by submerging themselves in the water, using their noses like snorkels. They are also known to run near other deer trying to shuck off the predator onto another unlucky animal.
Typically though they escape down a well known trail with twists and turns that the trailing predator has to figure out at every change. The path might have obstacles that the fleeing deer knows it can easily and expertly clear, while the pursuer has to figure them out, then wear itself out climbing, jumping, detouring or tunneling, all the while trying to keep track of its prey. Whitetail in a new, unknown territory are much more likely to be killed by predators.
Whitetail fawns start to practice their acrobatic survival skills when they are only days old. They will use their flimsy looking fawn legs to suddenly jump straight up in the air, maybe twisting in the air and landing at an angle, then lowering their heads like they have horns and are challenging an opponent...then it might be over, or the fawn might pop around escaping an imaginary predator for quite a while.
Then the time comes, and it doesn't take long, when the young fawn discovers speed...it will sprint, flat-out, close to the ground, suddenly change direction and run some more. If there are no playmates to frolic along it doesn't stop the fawn, it will sharpen its life-saving skills by itself.
Whitetail Survival
Whitetail Survival
I take that life if I can, with regret as well as joy, and with the sure knowledge that nature’s ways of fang and claw or exposure and starvation are a far crueler fate than I bestow. – Fred Bear
