With removeable Sony S40 4.1 Mega Pixel Digital Camera
System Overview:
Removeable Sony S40 4.1 Mp Digital Camera with 32 MB Internal memory Storage
Pix Controller LE II Electronic PIR Controller "Passive Infrared detection"
Pelican 1020 micro case Professionally dipped in Mossy Oak, Uv sealant protected against fading and 100% Waterproof New AA Batteries Included
New 9 Volt Battery Included
Pix Controller Board and Electronics Features and Operation:
Special Note: Detection Range will be effected by Heat/Cold... Range is Increased as Temperatures Fall and Decreases as Temperatures rise, On average 70 Feet is the detection range , This Encompasses all climate ranges, In cold climates detection past 100 feet is likely.This is due to the sensors ability to record Heat in relation to its surrounding ambient temperature
100 feet detection with Integrated PIR detection "Senses heat in Motion"
3 Picture Modes of Operation: Single Picture, Double Picture and Movie Mode
Low Power consumption 9 months battery Life ona singe 9 Volt Battery
3 Day/Night Modes of operation: Day Only/Night Only/24 Hour
4 adjustable delays: 10 seconds,2 minutes,5 minutes, 10 minutes
Control Leds: allows Visible confirmation of detection area, On/Off Selectable
Automatic Walk test mode: allows detection area testing w/walk away feature " self arms when done"
Low Battery confirmation: prevents false photos and powers unit down
Movie Mode: Takes Mpeg 15 second Movie clips at pre selected delay settings Night only/ Day only/ 24 Hour modes of operation
Selectable Dip switch controlled functions, easy and simple to setup and use
Conveinent Inner label depicting controller functions and operation
simple fast 1 minute or less setup, place it on the tree, turn on the switch, test detection area and walk away
Battery Life:
9Volts battery for electronic circuit board (can last up to 6 months)
Camera : 2 AA Depends on number of flash, temperature, quality of battery.
$265 postpaid to your door.........
