Great close to the firearm season
- Limbshot
- 2016 MEMBER OF THE YEAR
Well I made the decision to take a vacation day to hunt the last day of the firearm season and sit the stand where I missed to big 8 with my bow exactly two weeks prior. The morning was PERFECT! 24 degrees when I parked the car, crystal clear and not a breath of wind. The stage was set for a rematch, only this time, I had my trusty rifle. At 7:15, I had two does move across the ridge to my south and then something spooked them. They snorted and ran up the ridge and out of sight. At 8:20, I decided to rattle, hoping there was a cruising buck within earshot that was still looking for love. I completed a good fight sequence, hung my antlers up, grabbed my grunt call, grunted twice, then doe bleated twice, and grunted 4 or 5 more times and hung my call back on the hook. When I did, I looked across the field and saw a deer moving quickly behind some roses at about 80 yards. When he cleared the roses I could see a good solid rack with very good mass and I grabbed my rifle. He moved up to the field edge, about 60 yards away and stood there surveying the field, looking for the cause of all that commotion. Finding nothing, he turned and started walking east just inside the brush line, trying to get down wind as he walked through an opening at 60 yards, I grunted and he stopped perfectly. I settled the cross hairs and eased back on the trigger and BOOM. The deer hardly reacted and just walked forward about ten steps. Then he started doing the tail wiggle, once, twice, then non-stop and I knew he was hurting. He walked across the creek and bedded down. I started shaking. 15 minutes later as I stared his direction, he got up and walked 30 more yards and he bedded again. I knew he was in trouble. I waited 45 minutes after that and unloaded my rifle, lowered it and unhooked the safety harness and climbed down. Reloaded and slowly worked across the field. Took two steps into the woods and found great blood, followed it across the creek and up the steep incline and when I reached the top, I saw the deer stand up 30 yards away and he turned and walked straight away from me, then trotted a little then walked again. I could not get a follow up shot, nor was I going to shoot him up the rear. I decided to back out for 2 more hours to be safe. He was hit hard and losing a ton of blood. I returned two hours later and followed a pretty solid blood trail to where he laid expired. This deer is my personal best to date. I knew he was pretty good when I shot him, but had ZERO ground shrinkage. Honestly, when I walked up on him, he was bigger than I had expected. I was blown away by his mass and overall body size. I have not been this excited about a firearm kill of my own in a VERY long time.
- Buck-6b.jpg (90.58 KiB) Viewed 2336 times
- Buck-3b.jpg (89.02 KiB) Viewed 2336 times
- Buck-2b.jpg (93.06 KiB) Viewed 2336 times
Proud staffer for Bust-a-Buck scent products and U-Slide Bow Holder.
http://www.bustabuckdeerlure.com/
http://u-slide.com/
http://u-slide.com/
- Limbshot
Re: Great close to the firearm season
Couple more pics
- Buck-8b.jpg (103.48 KiB) Viewed 2335 times
- B-1.jpg (183.36 KiB) Viewed 2335 times
http://u-slide.com/
http://u-slide.com/
Congrats, awesome deer.
- Limbshot
Thanks Dave. The way the firearm season had been going, I almost didn't go, but I always say, it only takes one to change everything!!!
http://u-slide.com/
http://u-slide.com/
That's all it takes. for your area he has a fairly big body too. Nice going and way to hang in there.
- Limbshot
I should also mention, this IS NOT the deer I missed with my bow. He was taller, wider and not quite as heavy.
http://u-slide.com/
http://u-slide.com/
That's a good thing. Maybe he'll be there next year.Limbshot wrote:I should also mention, this IS NOT the deer I missed with my bow. He was taller, wider and not quite as heavy.
- Limbshot
Or late bow season...
http://u-slide.com/
http://u-slide.com/
Don't be greedy.Limbshot wrote:Or late bow season...
- Limbshot
http://u-slide.com/
http://u-slide.com/
PoisonSnake
- 2015 MEMBER OF THE YEAR
That is fantastic man.
- Limbshot
Thanks PS. Law of averages, sooner or later a good one had to cross my pass that I didn't mess up on!!!
http://u-slide.com/
http://u-slide.com/
- SAMCRO
- 2018 Member of the Year
I will preface the below by stating the obvious fact that SAMCRO would not have shot this animal. It is not up to the CRO's standards, and only would have been killed by accident. However, if we're being realistic, LS shot this deer by accident, as well, although the accident was on the part of the buck. I'm sure he's up in buck heaven somewhere, royally pissed off that his days were ended by a sawed-off little bastard, who added insult to injury with what appears to be a less-than-perfect shot.
However, having gotten that out of the way, let the CRO say this is a fine buck, and LS exceeded my expectations of him with this one. Nice work, and good show.
All you thugs and ugly mugs dealing drugs and making noise,
You can kill each other all you want but if you touch my little boys,
You begging for this bullet will be the last thing that you say
before I let my dark side come out to play
- Limbshot
http://u-slide.com/
http://u-slide.com/
